Salta al contenuto principale
HP Stream x360 11-p015wm Motherboard Replacement
Cosa ti serve
  1. HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: passo 1, immagine 1 di 2 HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Motherboard Replacement: passo 2, immagine 1 di 1
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Motherboard Replacement: passo 3, immagine 1 di 2 HP Stream x360 11-p015wm Motherboard Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Motherboard Replacement: passo 4, immagine 1 di 2 HP Stream x360 11-p015wm Motherboard Replacement: passo 4, immagine 2 di 2
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Motherboard Replacement: passo 6, immagine 1 di 3 HP Stream x360 11-p015wm Motherboard Replacement: passo 6, immagine 2 di 3 HP Stream x360 11-p015wm Motherboard Replacement: passo 6, immagine 3 di 3
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Motherboard Replacement: passo 7, immagine 1 di 2 HP Stream x360 11-p015wm Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Motherboard Replacement: passo 8, immagine 1 di 2 HP Stream x360 11-p015wm Motherboard Replacement: passo 8, immagine 2 di 2
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Motherboard Replacement: passo 9, immagine 1 di 3 HP Stream x360 11-p015wm Motherboard Replacement: passo 9, immagine 2 di 3 HP Stream x360 11-p015wm Motherboard Replacement: passo 9, immagine 3 di 3
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Motherboard Replacement: passo 10, immagine 1 di 2 HP Stream x360 11-p015wm Motherboard Replacement: passo 10, immagine 2 di 2
  11. HP Stream x360 11-p015wm Motherboard Replacement: passo 11, immagine 1 di 2 HP Stream x360 11-p015wm Motherboard Replacement: passo 11, immagine 2 di 2
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
Conclusione
IUPUI, Team S2-G3, Stella Fall 2019 Membro di IUPUI, Team S2-G3, Stella Fall 2019
IUPUI-STELLA-F19S2G3
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 739
