Salta al contenuto principale
HP Stream x360 11-p015wm Battery Replacement
Cosa ti serve
  1. HP Stream x360 11-p015wm Battery Replacement, Back Cover: passo 1, immagine 1 di 2 HP Stream x360 11-p015wm Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Battery Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    JIS Driver Set
    $19.99
    Compra
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Battery Replacement: passo 3, immagine 1 di 2 HP Stream x360 11-p015wm Battery Replacement: passo 3, immagine 2 di 2
    iFixit Opening Tool
    $1.99
    Compra
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Battery Replacement: passo 4, immagine 1 di 2 HP Stream x360 11-p015wm Battery Replacement: passo 4, immagine 2 di 2
    $3.99
    Compra
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Battery Replacement, Battery: passo 5, immagine 1 di 3 HP Stream x360 11-p015wm Battery Replacement, Battery: passo 5, immagine 2 di 3 HP Stream x360 11-p015wm Battery Replacement, Battery: passo 5, immagine 3 di 3
    • Use the JIS J1 screwdriver to remove the 6.5 mm screws surrounding the battery.
  6. HP Stream x360 11-p015wm Battery Replacement: passo 6, immagine 1 di 3 HP Stream x360 11-p015wm Battery Replacement: passo 6, immagine 2 di 3 HP Stream x360 11-p015wm Battery Replacement: passo 6, immagine 3 di 3
    • Using the iFixit tweezers, remove the cable connecting the battery to the motherboard.
    • Remove the wire located on the top side of the battery.
    • All connections should be removed. Simply remove the battery from the computer.
Conclusione
DaisyHaskell
Membro da: 10/15/18
683 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 532
