Salta al contenuto principale
HP Stream 8 Motherboard Replacement
Cosa ti serve
  1. HP Stream 8 Motherboard Replacement, Midframe: passo 1, immagine 1 di 1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Motherboard Replacement: passo 2, immagine 1 di 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Motherboard Replacement: passo 4, immagine 1 di 1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Motherboard Replacement, Front-Facing Camera: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Motherboard Replacement, Rear-Facing Camera: passo 7, immagine 1 di 1
    Compra
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Motherboard Replacement, Motherboard: passo 9, immagine 1 di 1
    Compra
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Motherboard Replacement: passo 10, immagine 1 di 1
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Motherboard Replacement: passo 11, immagine 1 di 1
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Motherboard Replacement: passo 12, immagine 1 di 1
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Motherboard Replacement: passo 13, immagine 1 di 1
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the motherboard from the device.
Conclusione
Nick Miller
Membro da: 04/11/16
669 Reputazione
6 Guide realizzate
Cal Poly, Team 34-14, Maness Spring 2016 Membro di Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,079
