Introduzione
If the Wi-Fi on your laptop is not working, it can be frustrating and disruptive to your daily tasks, especially in today's interconnected world. One of the common reasons for this issue could be a faulty or damaged Wi-Fi card. The Wi-Fi card, also known as a wireless network adapter, is the component responsible for connecting your laptop to wireless networks. Over time, due to various reasons like physical damage, overheating, or wear and tear, the Wi-Fi card may fail or malfunction. Additionally, to remove the motherboard of the laptop, the Wi-Fi card must be removed first.
In this guide, we will walk you through the steps to safely remove your laptop's Wi-Fi card. All you will need for this process is a Phillips #1 screwdriver and a plastic prying tool.
Cosa ti serve
Use an opening pick to gently pry up the edge of the rubber foot.
Grab the lifted edge of the foot and gently pull it away.
Repeat for the other rubber foot.
Remove the following Phillips screws that secure the battery:
Three 2.9 mm
Two 6.8 mm
