Salta al contenuto principale
HP Stream 13-c110nr WLAN Module Replacement
Cosa ti serve
  1. HP Stream 13-c110nr WLAN Module Replacement, Keyboard Assembly: passo 1, immagine 1 di 1
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr WLAN Module Replacement: passo 2, immagine 1 di 1
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr WLAN Module Replacement: passo 3, immagine 1 di 3 HP Stream 13-c110nr WLAN Module Replacement: passo 3, immagine 2 di 3 HP Stream 13-c110nr WLAN Module Replacement: passo 3, immagine 3 di 3
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr WLAN Module Replacement: passo 4, immagine 1 di 3 HP Stream 13-c110nr WLAN Module Replacement: passo 4, immagine 2 di 3 HP Stream 13-c110nr WLAN Module Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr WLAN Module Replacement: passo 5, immagine 1 di 1
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr WLAN Module Replacement: passo 6, immagine 1 di 3 HP Stream 13-c110nr WLAN Module Replacement: passo 6, immagine 2 di 3 HP Stream 13-c110nr WLAN Module Replacement: passo 6, immagine 3 di 3
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr WLAN Module Replacement: passo 7, immagine 1 di 1
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr WLAN Module Replacement: passo 8, immagine 1 di 2 HP Stream 13-c110nr WLAN Module Replacement: passo 8, immagine 2 di 2
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr WLAN Module Replacement: passo 9, immagine 1 di 2 HP Stream 13-c110nr WLAN Module Replacement: passo 9, immagine 2 di 2
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr WLAN Module Replacement: passo 10, immagine 1 di 1
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr WLAN Module Replacement, WLAN Module: passo 11, immagine 1 di 2 HP Stream 13-c110nr WLAN Module Replacement, WLAN Module: passo 11, immagine 2 di 2
    • Disconnect the WLAN antenna cable from the WLAN module.
  12. HP Stream 13-c110nr WLAN Module Replacement: passo 12, immagine 1 di 1
    • Remove one (1) Phillips P0 PM2.0x3.0 mm screw.
    • Place one (1) screw on magnetic mat for reassembly.
  13. HP Stream 13-c110nr WLAN Module Replacement: passo 13, immagine 1 di 1
    • Remove the WLAN Module from device.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 292
