Salta al contenuto principale
HP Stream 13-c110nr USB/Card Reader Board Replacement
Cosa ti serve
  1. HP Stream 13-c110nr USB/Card Reader Board Replacement, Keyboard Assembly: passo 1, immagine 1 di 1
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 2, immagine 1 di 1
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 3, immagine 1 di 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 3, immagine 2 di 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 3, immagine 3 di 3
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 4, immagine 1 di 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 4, immagine 2 di 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 5, immagine 1 di 1
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 6, immagine 1 di 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 6, immagine 2 di 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 6, immagine 3 di 3
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 7, immagine 1 di 1
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 8, immagine 1 di 2 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 8, immagine 2 di 2
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 9, immagine 1 di 2 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 9, immagine 2 di 2
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 10, immagine 1 di 1
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr USB/Card Reader Board Replacement, Battery Assembly: passo 11, immagine 1 di 2 HP Stream 13-c110nr USB/Card Reader Board Replacement, Battery Assembly: passo 11, immagine 2 di 2
    • Use a pick to detach the Battery assembly cable.
  12. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 12, immagine 1 di 2 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 12, immagine 2 di 2
    • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
    • Place eight (8) screws on magnetic mat for reassembly.
  13. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 13, immagine 1 di 1
    • Remove Battery Assembly from device.
  14. HP Stream 13-c110nr USB/Card Reader Board Replacement, USB/Card Reader Board: passo 14, immagine 1 di 2 HP Stream 13-c110nr USB/Card Reader Board Replacement, USB/Card Reader Board: passo 14, immagine 2 di 2
    • Use a pick to disconnect the USB/Card Reader cable from the System Board.
  15. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 15, immagine 1 di 2 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 15, immagine 2 di 2
    • Remove three (3) Phillips P0 PM2.0x3.0 mm screws.
    • Place three (3) screws on magnetic mat for reassembly.
  16. HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 16, immagine 1 di 2 HP Stream 13-c110nr USB/Card Reader Board Replacement: passo 16, immagine 2 di 2
    • Remove the USB/Card Reader board assembly from the device.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 317
