Salta al contenuto principale
HP Stream 13-c010nr Charging Port Replacement
Cosa ti serve
  1. HP Stream 13-c010nr Charging Port Replacement, HP Stream 13-c010nr Disassembly: passo 1, immagine 1 di 1
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Charging Port Replacement: passo 2, immagine 1 di 2 HP Stream 13-c010nr Charging Port Replacement: passo 2, immagine 2 di 2
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Charging Port Replacement: passo 3, immagine 1 di 2 HP Stream 13-c010nr Charging Port Replacement: passo 3, immagine 2 di 2
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Charging Port Replacement: passo 4, immagine 1 di 1
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr Charging Port Replacement, Charging Port: passo 5, immagine 1 di 1
    • Disconnect the charging port from the motherboard.
  6. HP Stream 13-c010nr Charging Port Replacement: passo 6, immagine 1 di 2 HP Stream 13-c010nr Charging Port Replacement: passo 6, immagine 2 di 2
    • Remove the two 5mm Phillips screws from the charging port.
    • Remove the bracket.
    • Pull out the charging port.
Conclusione
USF Tampa, Team S1-G3, Cagle Spring 2018 Membro di USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 495
