Salta al contenuto principale
Introduzione
A short battery life on the HP Stream 13-c010nr is a common problem experienced. Follow this guide to do the replacement yourself.
  1. Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. Remove the thirteen 5mm Phillips #0 screws from the bottom case. Remove the thirteen 5mm Phillips #0 screws from the bottom case.
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. Flip the laptop over and open it up. Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. Remove the eight 5mm Phillips #0 screws from the battery. Disconnect the battery from the motherboard.
    • Remove the eight 5mm Phillips #0 screws from the battery.
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
Conclusione
Keegan Lapham
Membro da: 22/02/2018
731 Reputazione
6 Guide realizzate
USF Tampa, Team S1-G3, Cagle Spring 2018 Membro di USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 882
