Salta al contenuto principale
HP Stream 13-c002dx Keyboard Replacement
Cosa ti serve
  1. HP Stream 13-c002dx Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 HP Stream 13-c002dx Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up.
    • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
    • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
    • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
  2. HP Stream 13-c002dx Keyboard Replacement: passo 2, immagine 1 di 3 HP Stream 13-c002dx Keyboard Replacement: passo 2, immagine 2 di 3 HP Stream 13-c002dx Keyboard Replacement: passo 2, immagine 3 di 3
    • Flip the laptop back over so it's right side up and open the screen.
    • Using a spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • Remove the keyboard assembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 769
