Introduzione
Use this guide to replace the battery in your HP Stream 13-c002dx. You may need to replace the battery in your HP Stream if it is having overheating issues or is unable to hold a charge. The tools required are listed below, but before beginning make sure the device is completely powered off and disconnected from any external power sources.
Flip the laptop over so the bottom is facing up and use your Phillips #0 screwdriver to remove the 11 visible 5mm screws on the back.
Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
You will notice various screws in the battery with letters A or B next to them. Using your Philips screwdriver, remove each of the 5 mm screws labeled A.
After removing and separating the screws labeled A, then remove the screws labeled B using the Phillips screwdriver. Remember to keep the A and B screws separate.
Altre 2 persone hanno completato questa guida.
