Salta al contenuto principale
HP Stream 11-y010nr WiFi Card Replacement
Cosa ti serve
  1. HP Stream 11-y010nr WiFi Card Replacement, Keyboard: passo 1, immagine 1 di 3 HP Stream 11-y010nr WiFi Card Replacement, Keyboard: passo 1, immagine 2 di 3 HP Stream 11-y010nr WiFi Card Replacement, Keyboard: passo 1, immagine 3 di 3
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr WiFi Card Replacement: passo 2, immagine 1 di 2 HP Stream 11-y010nr WiFi Card Replacement: passo 2, immagine 2 di 2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr WiFi Card Replacement: passo 3, immagine 1 di 2 HP Stream 11-y010nr WiFi Card Replacement: passo 3, immagine 2 di 2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr WiFi Card Replacement: passo 4, immagine 1 di 1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr WiFi Card Replacement: passo 5, immagine 1 di 3 HP Stream 11-y010nr WiFi Card Replacement: passo 5, immagine 2 di 3 HP Stream 11-y010nr WiFi Card Replacement: passo 5, immagine 3 di 3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr WiFi Card Replacement, WiFi Card: passo 6, immagine 1 di 3 HP Stream 11-y010nr WiFi Card Replacement, WiFi Card: passo 6, immagine 2 di 3 HP Stream 11-y010nr WiFi Card Replacement, WiFi Card: passo 6, immagine 3 di 3
    • Use your fingers or a spudger to pull the battery cable out from its connector.
  7. HP Stream 11-y010nr WiFi Card Replacement: passo 7, immagine 1 di 2 HP Stream 11-y010nr WiFi Card Replacement: passo 7, immagine 2 di 2
    • Gently pry up the two coaxial cables from the WiFi card with the needle nose tweezers.
  8. HP Stream 11-y010nr WiFi Card Replacement: passo 8, immagine 1 di 2 HP Stream 11-y010nr WiFi Card Replacement: passo 8, immagine 2 di 2
    • Unscrew the 0.3mm screw on the WiFi card with the Phillips #1 screwdriver.
  9. HP Stream 11-y010nr WiFi Card Replacement: passo 9, immagine 1 di 2 HP Stream 11-y010nr WiFi Card Replacement: passo 9, immagine 2 di 2
    • Gently pull the WiFi card out leftwards.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure that you put the wires on the Wifi card to the correct location. Each of the cables are numbered with the wifi card having the numbers next to each plug.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 629
