Introduzione
Is your HP Stream - y010nr screen not working? Did you accidentally drop it and break the screen? This guide will show you the proper steps to remove and replace the screen so it will be back in working condition.
Cosa ti serve
Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
Using your fingers or a spudger, pull the battery cable from its connector to disconnect power from the motherboard.
