Introduzione
This guide will show the step by step process of disassembling the HP stream in order to remove and replace the USB port.
Cosa ti serve
Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
Turn the device top down so the rubber feet are facing up.
Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
