Salta al contenuto principale
HP Stream 11-r020nr USB Port Replacement
Cosa ti serve
  1. HP Stream 11-r020nr USB Port Replacement, Keyboard Panel: passo 1, immagine 1 di 2 HP Stream 11-r020nr USB Port Replacement, Keyboard Panel: passo 1, immagine 2 di 2
    • Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
    • Turn the device top down so the rubber feet are facing up.
    • Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
  2. HP Stream 11-r020nr USB Port Replacement: passo 2, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove all 11 of the the 5mm screws.
  3. HP Stream 11-r020nr USB Port Replacement: passo 3, immagine 1 di 2 HP Stream 11-r020nr USB Port Replacement: passo 3, immagine 2 di 2
    • Flip the laptop over and open the laptop.
    • Using the blue plastic opening tool, separate the keyboard plate from the main body by prying up starting around the bottom corners, prying the bottom up first and the sides second all the way around the whole keyboard plate.
    • Be gentle when lifting the keyboard up as there will be ribbon cables still attaching the keyboard to the base of the laptop.
  4. HP Stream 11-r020nr USB Port Replacement: passo 4, immagine 1 di 2 HP Stream 11-r020nr USB Port Replacement: passo 4, immagine 2 di 2
    • Use the black nylon spudger to flip the black tab up that holds the ribbon cable in place.
    • Lift the ribbon cable free.
  5. HP Stream 11-r020nr USB Port Replacement: passo 5, immagine 1 di 2 HP Stream 11-r020nr USB Port Replacement: passo 5, immagine 2 di 2
    • Use the black nylon spudger to flip the black tab up that holds the large ribbon cable in place.
    • Pull the ribbon cable free from the base of the keyboard.
  6. HP Stream 11-r020nr USB Port Replacement: passo 6, immagine 1 di 2 HP Stream 11-r020nr USB Port Replacement: passo 6, immagine 2 di 2
    • Remove the tape covering the ribbon cable.
    • Pull the ribbon cable away from the base of the laptop.
  7. HP Stream 11-r020nr USB Port Replacement: passo 7, immagine 1 di 1
    • After detaching the two large ribbon cables, carefully lean the keyboard against the screen.
  8. HP Stream 11-r020nr USB Port Replacement, USB Port: passo 8, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the single 4mm screw.
    • The USB board is located in the bottom left corner.
  9. HP Stream 11-r020nr USB Port Replacement: passo 9, immagine 1 di 1
    • Use the black nylon spudger to flip the tab up that holds the ribbon cable in place.
  10. HP Stream 11-r020nr USB Port Replacement: passo 10, immagine 1 di 1
    • Gently pull out the ribbon cable with two fingers.
  11. HP Stream 11-r020nr USB Port Replacement: passo 11, immagine 1 di 1
    • Lift the USB port out and remove it from the device.
Conclusione
Un commento
Thanks for the info…whats the size of the charging port called
Mike Stewart - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 433
