Introduzione
This guide will show the step by step process of disassembling the HP stream in order to remove and replace the screen.
Cosa ti serve
Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
Turn the device top down so the rubber feet are facing up.
Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
Remove the power port 4 mm screw.
Using the Phillips #1 screwdriver, remove a total four 5 mm hinge screws.
Lift the screen up and away from the device.
Using the black nylon spudger, lift the top right corner of the frame from the screen.
From there, you can make your way around the screen. You will feel the frame pop off one at a time.
When you get to the bottom of the screen, place the plastic spudger between the screen and the frame and drag along the bottom to separate the adhesive.
Using the plastic spudger, separate the cosmetic stickers from the bottom left and right of the frame.
Using the Phillips #0 screwdriver, remove two 2mm screws, one on each side. Then remove the plastic covering the edge of the screen.
Continuing with the Phillips #0 screwdriver, remove four 2mm screws that hold the screen in place.
