Introduzione
Sometimes the ClickPad of the HP Stream 11-d020nr may stop working effectively. This could be caused by either a hardware or software issue. Either way, this replacement is pretty straightforward. To avoid potential electrical hazards, be sure that the laptop is unplugged and shut down before beginning your repair.
Cosa ti serve
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
On the back of the plastic keyboard cover, remove the two 2 mm Phillips #000 screws.
To reassemble your computer, follow these instructions in reverse order.
Altre 4 persone hanno completato questa guida.
2 Commenti
Can you give the Product number of the part?
