Salta al contenuto principale
HP Stream 11-d020nr Lid Replacement
Cosa ti serve
  1. HP Stream 11-d020nr Lid Replacement, Lower Case: passo 1, immagine 1 di 3 HP Stream 11-d020nr Lid Replacement, Lower Case: passo 1, immagine 2 di 3 HP Stream 11-d020nr Lid Replacement, Lower Case: passo 1, immagine 3 di 3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Lid Replacement: passo 2, immagine 1 di 2 HP Stream 11-d020nr Lid Replacement: passo 2, immagine 2 di 2
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Lid Replacement: passo 3, immagine 1 di 3 HP Stream 11-d020nr Lid Replacement: passo 3, immagine 2 di 3 HP Stream 11-d020nr Lid Replacement: passo 3, immagine 3 di 3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Lid Replacement: passo 4, immagine 1 di 3 HP Stream 11-d020nr Lid Replacement: passo 4, immagine 2 di 3 HP Stream 11-d020nr Lid Replacement: passo 4, immagine 3 di 3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
  5. HP Stream 11-d020nr Lid Replacement, Keyboard: passo 5, immagine 1 di 2 HP Stream 11-d020nr Lid Replacement, Keyboard: passo 5, immagine 2 di 2
    • Tilt the top of the keyboard plate up until you separate it from the base.
    • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
  6. HP Stream 11-d020nr Lid Replacement: passo 6, immagine 1 di 3 HP Stream 11-d020nr Lid Replacement: passo 6, immagine 2 di 3 HP Stream 11-d020nr Lid Replacement: passo 6, immagine 3 di 3
    • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
    • After disengaging the connectors, gently unplug both ribbon cables.
  7. HP Stream 11-d020nr Lid Replacement, Lid: passo 7, immagine 1 di 3 HP Stream 11-d020nr Lid Replacement, Lid: passo 7, immagine 2 di 3 HP Stream 11-d020nr Lid Replacement, Lid: passo 7, immagine 3 di 3
    • Lift the black flap on the display cable ZIF connector.
    • After lifting the flap, gently pull the display cable from its socket.
    • Disconnect the wireless antenna from the wireless card.
    • Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
  8. HP Stream 11-d020nr Lid Replacement: passo 8, immagine 1 di 3 HP Stream 11-d020nr Lid Replacement: passo 8, immagine 2 di 3 HP Stream 11-d020nr Lid Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the screw covers from the lid.
    • Remove the two 2.2 mm Phillips #000 screws.
    • Use a plastic opening tool to disengage the front part of the lid.
Conclusione
Spenser Mason
Membro da: 02/04/16
1.763 Reputazione
6 Guide realizzate
USF Tampa, Team 3-5, Wollert Spring 2016 Membro di USF Tampa, Team 3-5, Wollert Spring 2016
USFT-WOLLERT-S16S3G5
5 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 521
