Introduzione
An HP Stream 11-d010nr can develop a faulty clickpad through mechanical or electrical malfunctions. This replacement is fairly straightforward and should only take 5-10 minutes. Unplug and power off your device before you attempt to open the device.
  1. Unplug and turn off the HP Stream 11 before disassembling the device. Flip the device over.
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Flip the device over.
    • Using a metal spudger, pry off the two elliptical rubber inserts.
    • Using a metal spudger, pry off the two circular rubber inserts below the removed elliptical inserts.
  2. Using a JIS #1 screwdriver, remove the eleven 5.6 mm screws.
    • Using a JIS #1 screwdriver, remove the eleven 5.6 mm screws.
  3. Using an iFixit opening tool, pry open the case to separate the keyboard from the main body. HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
  6. Using your fingernail,  lift the flaps on the ZIF connectors that are securing the three ribbon cables. Carefully disconnect the three ribbon cables using two fingers. Carefully disconnect the three ribbon cables using two fingers.
    • Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
    • Carefully disconnect the three ribbon cables using two fingers.
  7. Lift the keyboard out of the laptop to remove it from the device.
    • Lift the keyboard out of the laptop to remove it from the device.
  8. Remove the two 2mm #000 Phillips screws. Remove the two 2mm #000 Phillips screws.
    • Remove the two 2mm #000 Phillips screws.
  9. Release the clickpad by lifting the keyboard up.
    • Release the clickpad by lifting the keyboard up.
    • When installing the new clickpad, make sure the black tabs go into the laptop.
Conclusione
Josh Corrigan
Membro da: 24/01/2019
323 Reputazione
2 Guide realizzate
Cal Poly, Team S1-G3, White Winter 2019 Membro di Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 55
