Salta al contenuto principale
HP Stream 11-d010nr Battery Replacement
Cosa ti serve
  1. HP Stream 11-d010nr Battery Replacement, Keyboard: passo 1, immagine 1 di 2 HP Stream 11-d010nr Battery Replacement, Keyboard: passo 1, immagine 2 di 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d010nr Battery Replacement: passo 2, immagine 1 di 1
    • Remove the eleven 5.6 mm Phillips #1 screws.
  3. HP Stream 11-d010nr Battery Replacement: passo 3, immagine 1 di 2 HP Stream 11-d010nr Battery Replacement: passo 3, immagine 2 di 2
    • Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Battery Replacement: passo 4, immagine 1 di 1
    • Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
  5. HP Stream 11-d010nr Battery Replacement: passo 5, immagine 1 di 3 HP Stream 11-d010nr Battery Replacement: passo 5, immagine 2 di 3 HP Stream 11-d010nr Battery Replacement: passo 5, immagine 3 di 3
    • Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Battery Replacement: passo 6, immagine 1 di 1
    • Lift the keyboard out of the laptop to remove it from the device.
  7. HP Stream 11-d010nr Battery Replacement, Battery: passo 7, immagine 1 di 1
    • Remove any tape holding the battery connector in place.
    • Using your fingers, carefully unplug the battery.
  8. HP Stream 11-d010nr Battery Replacement: passo 8, immagine 1 di 2 HP Stream 11-d010nr Battery Replacement: passo 8, immagine 2 di 2
    • Remove the four 3mm #000 Phillips screws holding the battery in place.
    • Carefully lift the battery out of the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S1-G3, White Winter 2019 Membro di Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 Membri
11 Guide realizzate
3 Commenti
HP lists the screws on the back cover as size pm1.9x5.6. What is wrong with HP that they would use such an odd size? I tried 2x6mm and they seem to work fine.
Greg Worrel - Replica
Me podrias ayudar con el numero de serie del boton de encendido
sam Carrizales - Replica
O donde lo puedo conseguir
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 40
Tutti i Tempi: 2,393
