Salta al contenuto principale
HP Stream 11-d008TU Power Button Replacement
Cosa ti serve
  1. HP Stream 11-d008TU Power Button Replacement, Rubber Feet Removal: passo 1, immagine 1 di 3 HP Stream 11-d008TU Power Button Replacement, Rubber Feet Removal: passo 1, immagine 2 di 3 HP Stream 11-d008TU Power Button Replacement, Rubber Feet Removal: passo 1, immagine 3 di 3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Power Button Replacement, Screw removal: passo 2, immagine 1 di 2 HP Stream 11-d008TU Power Button Replacement, Screw removal: passo 2, immagine 2 di 2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Power Button Replacement, Keyboard Unclipping: passo 3, immagine 1 di 3 HP Stream 11-d008TU Power Button Replacement, Keyboard Unclipping: passo 3, immagine 2 di 3 HP Stream 11-d008TU Power Button Replacement, Keyboard Unclipping: passo 3, immagine 3 di 3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Power Button Replacement, Keyboard removal: passo 4, immagine 1 di 3 HP Stream 11-d008TU Power Button Replacement, Keyboard removal: passo 4, immagine 2 di 3 HP Stream 11-d008TU Power Button Replacement, Keyboard removal: passo 4, immagine 3 di 3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Power Button Replacement, Connector removal: passo 5, immagine 1 di 2 HP Stream 11-d008TU Power Button Replacement, Connector removal: passo 5, immagine 2 di 2
    • Remove the power button connector from the power button by flipping the white tab up and pulling the ribbon cable out
  6. HP Stream 11-d008TU Power Button Replacement, Unscrew Button: passo 6, immagine 1 di 3 HP Stream 11-d008TU Power Button Replacement, Unscrew Button: passo 6, immagine 2 di 3 HP Stream 11-d008TU Power Button Replacement, Unscrew Button: passo 6, immagine 3 di 3
    • Unscrew the two Philips PH0 2.5mm screws
  7. HP Stream 11-d008TU Power Button Replacement: passo 7, immagine 1 di 3 HP Stream 11-d008TU Power Button Replacement: passo 7, immagine 2 di 3 HP Stream 11-d008TU Power Button Replacement: passo 7, immagine 3 di 3
    • Lift the power button out of the slot
Conclusione
Joel Taylor
Membro da: 03/07/20
1.346 Reputazione
8 Guide realizzate
Australia Membro di Australia
Community
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 419
