Salta al contenuto principale
HP Stream 11-d008TU Heatsink Replacement
Cosa ti serve
  1. HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: passo 1, immagine 1 di 3 HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: passo 1, immagine 2 di 3 HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: passo 1, immagine 3 di 3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Heatsink Replacement, Screw removal: passo 2, immagine 1 di 2 HP Stream 11-d008TU Heatsink Replacement, Screw removal: passo 2, immagine 2 di 2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: passo 3, immagine 1 di 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: passo 3, immagine 2 di 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: passo 3, immagine 3 di 3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: passo 4, immagine 1 di 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: passo 4, immagine 2 di 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: passo 4, immagine 3 di 3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Heatsink Replacement, Unscrew the heatsink: passo 5, immagine 1 di 1
    • Unscrew the four 2.5mm M2x2.5 PH-0 Phillips head screws in reverse numerical order (4-3-2-1)
    • 4: Bottom left | 3: Top Right | 2: Bottom Right | 1: Top Left
  6. HP Stream 11-d008TU Heatsink Replacement, Remove the heatsink: passo 6, immagine 1 di 2 HP Stream 11-d008TU Heatsink Replacement, Remove the heatsink: passo 6, immagine 2 di 2
    • Lift the heatsink
Conclusione
CONVERSION
Membro da: 03/07/20
1.252 Reputazione
8 Guide realizzate
Australia Membro di Australia
Community
3 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 70
