Salta al contenuto principale
HP Sprocket 2-in-1 Outer Casing Replacement
Cosa ti serve
  1. HP Sprocket 2-in-1 Outer Casing Replacement, Outer Casing: passo 1, immagine 1 di 2 HP Sprocket 2-in-1 Outer Casing Replacement, Outer Casing: passo 1, immagine 2 di 2
    • Remove the back cover and any printer paper inside the device.
  2. HP Sprocket 2-in-1 Outer Casing Replacement: passo 2, immagine 1 di 2 HP Sprocket 2-in-1 Outer Casing Replacement: passo 2, immagine 2 di 2
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
  3. HP Sprocket 2-in-1 Outer Casing Replacement: passo 3, immagine 1 di 3 HP Sprocket 2-in-1 Outer Casing Replacement: passo 3, immagine 2 di 3 HP Sprocket 2-in-1 Outer Casing Replacement: passo 3, immagine 3 di 3
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
  4. HP Sprocket 2-in-1 Outer Casing Replacement: passo 4, immagine 1 di 3 HP Sprocket 2-in-1 Outer Casing Replacement: passo 4, immagine 2 di 3 HP Sprocket 2-in-1 Outer Casing Replacement: passo 4, immagine 3 di 3
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
  5. HP Sprocket 2-in-1 Outer Casing Replacement: passo 5, immagine 1 di 2 HP Sprocket 2-in-1 Outer Casing Replacement: passo 5, immagine 2 di 2
    • Remove four 2.5mm JIS #00 screws from the beige casing.
  6. HP Sprocket 2-in-1 Outer Casing Replacement: passo 6, immagine 1 di 3 HP Sprocket 2-in-1 Outer Casing Replacement: passo 6, immagine 2 di 3 HP Sprocket 2-in-1 Outer Casing Replacement: passo 6, immagine 3 di 3
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
  7. HP Sprocket 2-in-1 Outer Casing Replacement: passo 7, immagine 1 di 1
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 338
