Salta al contenuto principale
HP Sprocket 2-in-1 Battery Replacement
Cosa ti serve
  1. HP Sprocket 2-in-1 Battery Replacement, Outer Casing: passo 1, immagine 1 di 2 HP Sprocket 2-in-1 Battery Replacement, Outer Casing: passo 1, immagine 2 di 2
    • Remove the back cover and any printer paper inside the device.
  2. HP Sprocket 2-in-1 Battery Replacement: passo 2, immagine 1 di 2 HP Sprocket 2-in-1 Battery Replacement: passo 2, immagine 2 di 2
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
  3. HP Sprocket 2-in-1 Battery Replacement: passo 3, immagine 1 di 3 HP Sprocket 2-in-1 Battery Replacement: passo 3, immagine 2 di 3 HP Sprocket 2-in-1 Battery Replacement: passo 3, immagine 3 di 3
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
  4. HP Sprocket 2-in-1 Battery Replacement: passo 4, immagine 1 di 3 HP Sprocket 2-in-1 Battery Replacement: passo 4, immagine 2 di 3 HP Sprocket 2-in-1 Battery Replacement: passo 4, immagine 3 di 3
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
  5. HP Sprocket 2-in-1 Battery Replacement: passo 5, immagine 1 di 2 HP Sprocket 2-in-1 Battery Replacement: passo 5, immagine 2 di 2
    • Remove four 2.5mm JIS #00 screws from the beige casing.
  6. HP Sprocket 2-in-1 Battery Replacement: passo 6, immagine 1 di 3 HP Sprocket 2-in-1 Battery Replacement: passo 6, immagine 2 di 3 HP Sprocket 2-in-1 Battery Replacement: passo 6, immagine 3 di 3
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
  7. HP Sprocket 2-in-1 Battery Replacement: passo 7, immagine 1 di 1
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
  8. HP Sprocket 2-in-1 Battery Replacement, Battery: passo 8, immagine 1 di 2 HP Sprocket 2-in-1 Battery Replacement, Battery: passo 8, immagine 2 di 2
    • Use a JIS #00 screwdriver to remove a single black screw near the viewfinder.
    • Remove a single silver 2.5mm JIS #00 screw near the USB port of the device.
    • Carefully remove the metal bracket.
  9. HP Sprocket 2-in-1 Battery Replacement: passo 9, immagine 1 di 1
    • Work the battery free from the device with the iFixit opening tool.
    • Carefully disconnect the battery from the board.
Conclusione
Altre 2 persone hanno completato questa guida.
7 Commenti
Awesome guide. Just turned on my sprocket after 9 months and the battery is definitely dead. I will definitely be using your guide in the days to come. But where did you get the replacement battery from?
Cheers,
Big Peltch - Replica
Did you ever figure out where to buy a battery?
Michael Staats -
The original post is old asking where to find a replacement battery, but hopefully this post will help those that find this installation video. Amazon has the batteries for about $26.00. Here’s a link to help out.
Replacement Battery for HP Sprocket 200,PN:1AS84-60006,Photo Printer Battery https://a.co/d/2gML4tv
Cafe Chic -
Hola, donde puedo comprar la bateria de HP Sprocket 100? Li-ion Polymer Battery Model: P0562-LF. Desde ya muchas gracias.
Daniel Stizza - Replica
Muy bonito todo.
Acudí al soporte HP y me dicen que no hay batería de reemplazo. La he buscado en muchos sitios y nada.
¿En qué sitio la podré conseguir?
Fernando - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 56
Tutti i Tempi: 5,286
