Salta al contenuto principale
HP Split x2 13-g210dx Back Panel Replacement
Cosa ti serve
  1. HP Split x2 13-g210dx Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
Conclusione
Un commento
How do I put the felt cover back on?
Prince Phoenix - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 389
