Introduzione
This guide will show you how to replace the display of Spectre 13’’ (Model: 13-ac023dx). This guide will be helpful when the display is damaged. The most common defect is the black screen. No special skills are required for this operation.
Warning: Ensure you turn off your device before starting.
Cosa ti serve
Lay the laptop flat on the table with the keyboard side facing the table and the motherboard facing up.
Move the metal components that were just unscrewed out of the way to make a clear view of the two display connectors.
Flip up both latches that are found at the center of the computer's body where the wires connect to the motherboard. Then release the wires that attach to the display. This will separate the two main parts of the computer.
Altre 2 persone hanno completato questa guida.
Un commento
I couldn’t remove the display without removing the one speaker. In the pictures, you can easily see that he just bent the metal case at the hinge and pried it out.
