Salta al contenuto principale
HP Spectrex360 13-ac023dx Display Replacement
Cosa ti serve
  1. HP Spectrex360 13-ac023dx Display Replacement, Battery: passo 1, immagine 1 di 2 HP Spectrex360 13-ac023dx Display Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectrex360 13-ac023dx Display Replacement: passo 2, immagine 1 di 3 HP Spectrex360 13-ac023dx Display Replacement: passo 2, immagine 2 di 3 HP Spectrex360 13-ac023dx Display Replacement: passo 2, immagine 3 di 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectrex360 13-ac023dx Display Replacement: passo 3, immagine 1 di 2 HP Spectrex360 13-ac023dx Display Replacement: passo 3, immagine 2 di 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectrex360 13-ac023dx Display Replacement, Display: passo 4, immagine 1 di 1
    • Lay the laptop flat on the table with the keyboard side facing the table and the motherboard facing up.
  5. HP Spectrex360 13-ac023dx Display Replacement: passo 5, immagine 1 di 3 HP Spectrex360 13-ac023dx Display Replacement: passo 5, immagine 2 di 3 HP Spectrex360 13-ac023dx Display Replacement: passo 5, immagine 3 di 3
    • Using the Phillips #000 screwdriver, remove the four 1.0 mm screws that attach the display to the main body of the computer.
  6. HP Spectrex360 13-ac023dx Display Replacement: passo 6, immagine 1 di 3 HP Spectrex360 13-ac023dx Display Replacement: passo 6, immagine 2 di 3 HP Spectrex360 13-ac023dx Display Replacement: passo 6, immagine 3 di 3
    • Move the metal components that were just unscrewed out of the way to make a clear view of the two display connectors.
    • Flip up both latches that are found at the center of the computer's body where the wires connect to the motherboard. Then release the wires that attach to the display. This will separate the two main parts of the computer.
  7. HP Spectrex360 13-ac023dx Display Replacement: passo 7, immagine 1 di 2 HP Spectrex360 13-ac023dx Display Replacement: passo 7, immagine 2 di 2
    • Separate the display from the bottom half of the computer(motherboard).
Conclusione
Altre 2 persone hanno completato questa guida.
Jonathan
Membro da: 10/21/19
486 Reputazione
4 Guide realizzate
Un commento
I couldn’t remove the display without removing the one speaker. In the pictures, you can easily see that he just bent the metal case at the hinge and pried it out.
Ryan Stauffer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 67
Tutti i Tempi: 2,546
