Salta al contenuto principale
HP Spectre x360 13t-4000 Wifi Adapter Replacement
Cosa ti serve
  1. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Bottom Cover: passo 1, immagine 1 di 2 HP Spectre x360 13t-4000 Wifi Adapter Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Wifi Adapter Replacement: passo 2, immagine 1 di 2 HP Spectre x360 13t-4000 Wifi Adapter Replacement: passo 2, immagine 2 di 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Wifi Adapter Replacement: passo 3, immagine 1 di 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement: passo 3, immagine 2 di 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement: passo 3, immagine 3 di 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Battery: passo 4, immagine 1 di 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement, Battery: passo 4, immagine 2 di 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement, Battery: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Wifi Adapter: passo 5, immagine 1 di 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement, Wifi Adapter: passo 5, immagine 2 di 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement, Wifi Adapter: passo 5, immagine 3 di 3
    Compra
    • Using a Phillips#0 screwdriver, remove the 2 mm screw.
    • Located to the right of the screw, there are two wires connected to the adapter. Using tweezers, carefully remove the wires.
    • There may be tape covering the wires.
    • Now you can remove the adapter by pulling it from its socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 926
