Salta al contenuto principale
HP Spectre x360 13t-4000 Speakers Replacement
Cosa ti serve
  1. HP Spectre x360 13t-4000 Speakers Replacement, Bottom Cover: passo 1, immagine 1 di 2 HP Spectre x360 13t-4000 Speakers Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Speakers Replacement: passo 2, immagine 1 di 2 HP Spectre x360 13t-4000 Speakers Replacement: passo 2, immagine 2 di 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Speakers Replacement: passo 3, immagine 1 di 3 HP Spectre x360 13t-4000 Speakers Replacement: passo 3, immagine 2 di 3 HP Spectre x360 13t-4000 Speakers Replacement: passo 3, immagine 3 di 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Speakers Replacement, Battery: passo 4, immagine 1 di 3 HP Spectre x360 13t-4000 Speakers Replacement, Battery: passo 4, immagine 2 di 3 HP Spectre x360 13t-4000 Speakers Replacement, Battery: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 Speakers Replacement, Speakers: passo 5, immagine 1 di 3 HP Spectre x360 13t-4000 Speakers Replacement, Speakers: passo 5, immagine 2 di 3 HP Spectre x360 13t-4000 Speakers Replacement, Speakers: passo 5, immagine 3 di 3
    • With the backplate and battery removed from the device, remove the three 2mm screws using the Phillips #0 screwdriver.
  6. HP Spectre x360 13t-4000 Speakers Replacement: passo 6, immagine 1 di 2 HP Spectre x360 13t-4000 Speakers Replacement: passo 6, immagine 2 di 2
    • With all three screws removed, remove the speaker assembly from the device.
Conclusione
Michael Bisbano
Membro da: 03/18/19
88 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,296
