Introduzione
This guide will instruct you on how to remove and replace the fan. Replacement of the fan may be necessary if the laptop is overheating.
Cosa ti serve
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
Use a Phillips #0 screwdriver to unscrew and remove the two 4 mm screws that secure the fan.
Use the same screwdriver to remove the four 3 mm screws to free the heat sink.
Quasi finito!
Conclusione
