Salta al contenuto principale
HP Spectre x360 13t-4000 Fan Replacement
Cosa ti serve
  1. HP Spectre x360 13t-4000 Fan Replacement, Bottom Cover: passo 1, immagine 1 di 2 HP Spectre x360 13t-4000 Fan Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Fan Replacement: passo 2, immagine 1 di 2 HP Spectre x360 13t-4000 Fan Replacement: passo 2, immagine 2 di 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Fan Replacement: passo 3, immagine 1 di 3 HP Spectre x360 13t-4000 Fan Replacement: passo 3, immagine 2 di 3 HP Spectre x360 13t-4000 Fan Replacement: passo 3, immagine 3 di 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Fan Replacement, Fan: passo 4, immagine 1 di 3 HP Spectre x360 13t-4000 Fan Replacement, Fan: passo 4, immagine 2 di 3 HP Spectre x360 13t-4000 Fan Replacement, Fan: passo 4, immagine 3 di 3
    • Use a Phillips #0 screwdriver to unscrew and remove the two 4 mm screws that secure the fan.
    • Use the same screwdriver to remove the four 3 mm screws to free the heat sink.
  5. HP Spectre x360 13t-4000 Fan Replacement: passo 5, immagine 1 di 1
    • Remove the fan cable.
  6. HP Spectre x360 13t-4000 Fan Replacement: passo 6, immagine 1 di 3 HP Spectre x360 13t-4000 Fan Replacement: passo 6, immagine 2 di 3 HP Spectre x360 13t-4000 Fan Replacement: passo 6, immagine 3 di 3
    • Peal off the tape with the metal shield, heat sink, and the fan attached to it.
    • Gently separate the fan from the heat sink in order to replace the fan.
Conclusione
Justin Dages
Membro da: 03/28/23
361 Reputazione
3 Guide realizzate
IUPUI, Team 2-5, Harley Spring 2023 Membro di IUPUI, Team 2-5, Harley Spring 2023
IUPUI-HARLEY-S23S2G5
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 92
