Introduzione
The laptop needs to be powered off before starting disassembly. The heat sink removes heat from the laptop. If you are experiencing overheating problems then you may need to replace the heat sink.
Cosa ti serve
Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
Quasi finito!
Conclusione
