Salta al contenuto principale
HP Spectre 13-4002dx Battery Replacement
Cosa ti serve
  1. HP Spectre 13-4002dx Battery Replacement, Bottom Case: passo 1, immagine 1 di 2 HP Spectre 13-4002dx Battery Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Battery Replacement: passo 2, immagine 1 di 2 HP Spectre 13-4002dx Battery Replacement: passo 2, immagine 2 di 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Battery Replacement, Battery: passo 3, immagine 1 di 3 HP Spectre 13-4002dx Battery Replacement, Battery: passo 3, immagine 2 di 3 HP Spectre 13-4002dx Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Battery Replacement: passo 4, immagine 1 di 3 HP Spectre 13-4002dx Battery Replacement: passo 4, immagine 2 di 3 HP Spectre 13-4002dx Battery Replacement: passo 4, immagine 3 di 3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Battery Replacement: passo 5, immagine 1 di 2 HP Spectre 13-4002dx Battery Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Battery Replacement: passo 6, immagine 1 di 3 HP Spectre 13-4002dx Battery Replacement: passo 6, immagine 2 di 3 HP Spectre 13-4002dx Battery Replacement: passo 6, immagine 3 di 3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Battery Replacement: passo 7, immagine 1 di 1
    • Carefully remove the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,275
