Salta al contenuto principale
HP Spectre 13-3010dx Fan Replacement
Cosa ti serve
  1. HP Spectre 13-3010dx Fan Replacement, Removal of the Back Case: passo 1, immagine 1 di 2 HP Spectre 13-3010dx Fan Replacement, Removal of the Back Case: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Put on Anti Static Wrist Strap.
    • It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
    • Flip Computer Upside down.
    • Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
  2. HP Spectre 13-3010dx Fan Replacement: passo 2, immagine 1 di 2 HP Spectre 13-3010dx Fan Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to lift the back case off.
    • Use the plastic opening tools first; metal spudgers can damage your device.
  3. HP Spectre 13-3010dx Fan Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
  4. HP Spectre 13-3010dx Fan Replacement: passo 4, immagine 1 di 1
    • Gently unplug from CONO851 plug, using the plastic opening tool.
  5. HP Spectre 13-3010dx Fan Replacement: passo 5, immagine 1 di 2 HP Spectre 13-3010dx Fan Replacement: passo 5, immagine 2 di 2
    • Gently lift up the battery and remove using the plastic opening tools.
  6. HP Spectre 13-3010dx Fan Replacement, Fan: passo 6, immagine 1 di 1
    • Unscrew three 2.0 mm screws using the Phillips Head #0
  7. HP Spectre 13-3010dx Fan Replacement: passo 7, immagine 1 di 1
    • Disconnect the plug.
  8. HP Spectre 13-3010dx Fan Replacement: passo 8, immagine 1 di 1
    • Remove the fan.
Conclusione
Altre 6 persone hanno completato questa guida.
2 Commenti
Why did you physically remove the battery? It seems like unplugging the battery’s CONO851 plug would be good enough? It’s funny, even in the photo where you remove the fan, the battery is still there.
tshong - Replica
I replaced the fan in my computer. As tshong said, I did not have to remove the battery. Just unplugged it then skipped steps 3 and 5. and voila.
Trach Nguyen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,434
