Introduzione
This guide will help you fix your faulty charge port. Make sure you are wearing the Anti-Static Wrist Strap and remove the battery before beginning this guide to avoid any damage to your computer.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Anti-Static Wrist Strap$7.95
Put on Anti Static Wrist Strap.
Flip Computer Upside down.
Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
Remove the two 2.0 mm screws in the charge port bracket using the PH00 screw head.
Altre 4 persone hanno completato questa guida.
