Introduzione
Use the Back Case Removal Guide as a prerequisite to this guide. Make sure you are wearing the Anti-Static Wrist Strap to avoid damaging the electronics.
It is always a good idea to remove the battery before working on any other components, for the safety of you and your computer.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Anti-Static Wrist Strap$7.95
Put on Anti Static Wrist Strap.
Flip Computer Upside down.
Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
Altre 11 persone hanno completato questa guida.
4 Commenti
Good Job presenting the steps. I need to find a battery for my hp 13-3010dx ultrabook. Any ideas where one can be purchased.
Hi Dawson Wilke, the battery seems has two kinds of interface, I suggest you take out your old battery check the battery model and product parameter, such as voltage and current as well as the interface, then search the right battery from online store. If you confuse on it, I am here willing to help you.
julie -
Hi i did this found a battery online and did an installation of the replacement. Unfortunately it is not an original hp battery as none are available. However the issue I am having is that the new battery is not being detected. Any recommendations?
HP Spectre 13-3010dx Battery Replacement
