Introduzione
This guide will give you step-by-step instructions on how to replace your display assembly. Make sure you have a clean, dry, uncluttered, and roomy work space that has good lighting before you start. Also, make sure that your display assembly actually needs to be replaced by consulting our troubleshooting guide.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Turn the computer upside down.
Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
Remove the two 2mm Phillips #00 screws from the fan.
Disconnect the fan from the motherboard.
Altre 7 persone hanno completato questa guida.
2 Commenti
You forgot to mention that some people may have to remove the heatsink like I did before the screen will come off.
Anyone have any tips on reconnecting the WIFI antennas? I finally gave up and just decided to get a USB dongleā¦ worked out well otherwise. I did also have to remove the heatsink like Wargaming Super Noob mentioned.
