Salta al contenuto principale
HP Slate 8 Pro Speakers Replacement
Cosa ti serve
  1. HP Slate 8 Pro Speakers Replacement, Remove back cover: passo 1, immagine 1 di 1
    • Use plastic opening tool to pry back panel off.
  2. HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: passo 2, immagine 1 di 2 HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: passo 2, immagine 2 di 2
    • Remove the orange and yellow ribbon cables.
    • detach the screws along the IO board
  3. HP Slate 8 Pro Speakers Replacement, Remove the IO board and the speakers: passo 3, immagine 1 di 1
    • Remove the IO board and the speakers circuit. Note that they are held together.
  4. HP Slate 8 Pro Speakers Replacement, Detach the speakers from the IO board.: passo 4, immagine 1 di 1
    • The tablet has two speakers. Each speaker is located to both sides of the IO board.
    • Detach the speakers from the cables that connect the speakers and the IO board. You will find more details in step 5 and 6.
  5. HP Slate 8 Pro Speakers Replacement, Remove the wires of the speakers from the IO board.: passo 5, immagine 1 di 1
    • To remove the cables that connect the speakers and the IO board, apply a subtle pressure to pull the cable out.
  6. HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: passo 6, immagine 1 di 2 HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: passo 6, immagine 2 di 2
    • Once you detach the speakers from the IO board, you should have three pieces as shown.
    • You are ready to replace the speakers.
Conclusione
Jose Revelo
Membro da: 09/23/14
305 Reputazione
3 Guide realizzate
USF Tampa, Team 9-4, Blackwell Fall 2014 Membro di USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 431
