Salta al contenuto principale
Introduzione
Use this guide to replace your HP Slate 8 Pro motherboard.
  1. Secure the suction cup to the center of the device’s screen. Begin to pull upwards with the suction cup. While pulling, start easing the plastic opening tool into the space between the screen and the device. This will gradually separate the screen from the plastic back panel.
    • Secure the suction cup to the center of the device’s screen.
    • Begin to pull upwards with the suction cup. While pulling, start easing the plastic opening tool into the space between the screen and the device. This will gradually separate the screen from the plastic back panel.
  2. Use a spudger tool to release the black clips on the two connectors holding the flat, yellow cable in place. Use the tweezers to pull the flat, yellow cable out of its connectors.
    • Use a spudger tool to release the black clips on the two connectors holding the flat, yellow cable in place.
    • Use the tweezers to pull the flat, yellow cable out of its connectors.
    • Use the tweezers to disconnect the battery connector from the circuit board.
    • Using the spudger tool again, pry up and release the connectors at the ends of the flat, orange cable.
    • Remove the flat, orange cable.
  3. As shown, the battery is held in place by a total of 8 screws. Use the #00 Phillips screwdriver to remove all 8.
    • As shown, the battery is held in place by a total of 8 screws. Use the #00 Phillips screwdriver to remove all 8.
  4. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  5. Grasp the battery and remove it from the device.
    • Grasp the battery and remove it from the device.
    • Do not attempt to open or tamper with the battery. This could result in injury.
  6. Disconnect the five connectors.
    • Disconnect the five connectors.
    • With the zero insertion force connectors, be sure to flip up the tab to avoid damaging the connector.
    • Use tweezers to disconnect the three antenna connectors
  7. Remove the four PH#00 2.4mm screws that hold in the motherboard in place.
    • Remove the four PH#00 2.4mm screws that hold in the motherboard in place.
  8. Use tweezers and a spudger to remove the motherboard.
    • Use tweezers and a spudger to remove the motherboard.
    • You may have to use a spudger to scrape off the adhesive holding the motherboard in place.
Conclusione
Andrew Hall
Membro da: 23/05/2016
322 Reputazione
3 Guide realizzate
IUPUI, Team 1-4, Renguette SU 2016 Membro di IUPUI, Team 1-4, Renguette SU 2016
IUPUI-RENGUETTE-SU16S1G4
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 324
