Salta al contenuto principale
HP Slate 8 Pro Microphone Replacement
Cosa ti serve
  1. HP Slate 8 Pro Microphone Replacement, Remove the back cover: passo 1, immagine 1 di 1
    • Before opening your device, turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down through the operating system.
    • Unplug your tablet from any power supply
    • Remove all external devices.
    • Remove back cover with plastic tools to avoid scratching the screen.
  2. HP Slate 8 Pro Microphone Replacement, Remove screws: passo 2, immagine 1 di 1
    • Remove all screws from the sides of the battery
  3. HP Slate 8 Pro Microphone Replacement, Disconnect the battery cable: passo 3, immagine 1 di 1
    • Disconnect the battery cable from the system board.
    • Use a little bit of pressure to remove the cable.
  4. HP Slate 8 Pro Microphone Replacement, Remove ZIF connector: passo 4, immagine 1 di 1
    • Release the ZIF connector to which the microphone cable is attached
  5. HP Slate 8 Pro Microphone Replacement, Remove the  microphone: passo 5, immagine 1 di 1
    • Remove microphone from panel using tweezers
    • Add your new microphone
Conclusione
Claudia
Membro da: 08/31/14
246 Reputazione
2 Guide realizzate
USF Tampa, Team 9-4, Blackwell Fall 2014 Membro di USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 9
Tutti i Tempi: 401
