Salta al contenuto principale
HP Slate 7 Plus 4200US Tablet Cover Replacement
Cosa ti serve
  1. HP Slate 7 Plus 4200US Tablet Cover Replacement, Tablet Cover: passo 1, immagine 1 di 1
    • Turn off the tablet and disconnect the power and all external devices from the tablet.
    • Position the tablet with the display panel down and the right side toward you.
    • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
  2. HP Slate 7 Plus 4200US Tablet Cover Replacement: passo 2, immagine 1 di 2 HP Slate 7 Plus 4200US Tablet Cover Replacement: passo 2, immagine 2 di 2
    • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
  3. HP Slate 7 Plus 4200US Tablet Cover Replacement: passo 3, immagine 1 di 3 HP Slate 7 Plus 4200US Tablet Cover Replacement: passo 3, immagine 2 di 3 HP Slate 7 Plus 4200US Tablet Cover Replacement: passo 3, immagine 3 di 3
    • Pry open the back cover to take it off.
Conclusione
USF Tampa, Team 3-1, Sullivan Fall 2016 Membro di USF Tampa, Team 3-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G1
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 279
