Salta al contenuto principale
HP Slate 7 Plus 4200US Front Facing Webcamera Replacement
Cosa ti serve
  1. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Tablet Cover: passo 1, immagine 1 di 1
    • Turn off the tablet and disconnect the power and all external devices from the tablet.
    • Position the tablet with the display panel down and the right side toward you.
    • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
  2. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: passo 2, immagine 1 di 2 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: passo 2, immagine 2 di 2
    • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
  3. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: passo 3, immagine 1 di 3 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: passo 3, immagine 2 di 3 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: passo 3, immagine 3 di 3
    • Pry open the back cover to take it off.
  4. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Battery: passo 4, immagine 1 di 3 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Battery: passo 4, immagine 2 di 3 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Battery: passo 4, immagine 3 di 3
    • Disconnect the battery cables from the system board by desoldering them. See iFixit guide on how to solder.
    • The battery cables are soldered to the system in the following sequence, top to bottom: red, blue, green, yellow, black.
  5. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: passo 5, immagine 1 di 3 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: passo 5, immagine 2 di 3 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: passo 5, immagine 3 di 3
    • Insert a nylon spudger between the battery and the display panel assembly. Carefully pry the battery up and remove it from its place.
    • The battery is attached to the display panel assembly with double-sided adhesive. Make sure to firmly pull the battery.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  6. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Front Facing Webcamera: passo 6, immagine 1 di 2 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Front Facing Webcamera: passo 6, immagine 2 di 2
    • Use tweezers to remove the black foam stickers from the front facing camera to expose the wiring.
  7. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: passo 7, immagine 1 di 2 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: passo 7, immagine 2 di 2
    • Lift the camera out from system board and firmly pull the wire out from the connector.
Conclusione
USF Tampa, Team 3-1, Sullivan Fall 2016 Membro di USF Tampa, Team 3-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G1
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 106
