Salta al contenuto principale
HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement
Cosa ti serve
  1. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: passo 1, immagine 1 di 3 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: passo 1, immagine 2 di 3 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: passo 1, immagine 3 di 3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: passo 2, immagine 1 di 3 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: passo 2, immagine 2 di 3 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: passo 2, immagine 3 di 3
    • Pull back the tape holding the the camera's connector strip to the device.
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Gently pull the camera's connecting strip out from the port.
Conclusione
Riley Wells
Membro da: 09/15/16
111 Reputazione
1 Guida realizzata
USF Tampa, Team 11-4, Blackwell Fall 2016 Membro di USF Tampa, Team 11-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G4
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 156
