Introduzione
This guide will require caution when connection replacing, due to the strip being easily ripped.
  1. Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up. Once all sides have been pried up, pull the cover off and place it to the side. Once all sides have been pried up, pull the cover off and place it to the side.
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. Use the  PH #000 phillips head screw driver to remove one 5.0 mm screw. Move plastic housing and rear facing camera to expose silver bracket.
    • Use the PH #000 phillips head screw driver to remove one 5.0 mm screw.
    • Move plastic housing and rear facing camera to expose silver bracket.
  3. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  4. Use the PH #000 phillips head screw driver to remove three 3.0mm screws. Remove the silver bracket. Use the PH #000 phillips head screw driver to remove three 3.0mm screws. Remove the silver bracket.
    • Use the PH #000 phillips head screw driver to remove three 3.0mm screws. Remove the silver bracket.
  5. Use the nylon spudger to flip  up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place. Grab the green circuit board and pull directly up to separate the glued down power strip. Gently pull the circuit board out of its connector.
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Grab the green circuit board and pull directly up to separate the glued down power strip.
    • Gently pull the circuit board out of its connector.
Conclusione
Brandon Ko
Membro da: 15/09/2016
698 Reputation
6 Guide realizzate
USF Tampa, Team 11-4, Blackwell Fall 2016 Membro di USF Tampa, Team 11-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G4
4 Membri
16 Guide realizzate
where can i get the part at?
cat jones - Replica
Where do you even get the part at??
Mountiansurfer Gaming - Replica
Where do I even get the part at???
Can you let us know where to get the replacement part from?
ypk77 - Replica
This is completely useless information without a source for the shoddy HP part!
Brian Burke - Replica
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 30
All Time: 1,429
