Introduzione
NOTE: HP recommends that the scanner is allowed to cool down for 15 minutes after being disconnected from power before performing this procedure.
NOTE: Clean the outside of the scanner before performing this procedure to prevent contamination of internal parts.
Cosa ti serve
Strumento utilizzato in questo passaggio:Heavy-Duty Suction Cups (Pair)$16.95
The top has to be lifted straight up at the front and back at the same time.
I found Heavy-Duty Suction Cups (Pair) to work best, but due to the structure of the plastic they quickly loose their grip, so work fast.
Alternative: Lift the top cover in the back as little as possible and use Plastic Cards to work your way to the front until you are able to get a grip of the whole top cover and lift it straight up.
Altre 4 persone hanno completato questa guida.
