Salta al contenuto principale
HP ProBook x360 11 G5 EE Charging Port Replacement
Cosa ti serve
  1. HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: passo 1, immagine 1 di 3 HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: passo 1, immagine 2 di 3 HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: passo 1, immagine 3 di 3
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 2, immagine 1 di 1
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 3, immagine 1 di 3 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 3, immagine 2 di 3 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 3, immagine 3 di 3
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 4, immagine 1 di 3 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 4, immagine 2 di 3 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 4, immagine 3 di 3
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 5, immagine 1 di 2 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 5, immagine 2 di 2
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: passo 6, immagine 1 di 2 HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 7, immagine 1 di 3 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 7, immagine 2 di 3 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 7, immagine 3 di 3
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: passo 8, immagine 1 di 2 HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: passo 8, immagine 2 di 2
    • Remove the single 3 mm screw from the charging port using a T5 Torx screwdriver.
  9. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 9, immagine 1 di 3 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 9, immagine 2 di 3 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 9, immagine 3 di 3
    • Disconnect the charging port wire from the motherboard.
    • Remove the charging port from your device.
Conclusione
Michelle Pina
Membro da: 10/26/21
506 Reputazione
4 Guide realizzate
Gateway, Team 1-4, Pee Fall 2021 Membro di Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
5 Membri
5 Guide realizzate
2Commenti sulla guida
Hi!! I have the same model of notebook with 64 giga emmc. Is it possible installing an ssd or an hdd?
Riccardo Insolera - Replica
I followed each and every step, and realised a little too late that my laptop is a HP ProBook x360 11 G1 -and not a G5. The G1 requires the ability to de-solder the built in charging port.
On step 6, I noticed there were 6 screws holding the battery in, not 4.
Then on step 9, I noticed that the charging port is actually soldered to the motherboard and there is no visible cable attaching it to the board which can be unhooked.
Sam T - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 63
Tutti i Tempi: 1,209
