Salta al contenuto principale
HP ProBook x360 11 G5 EE Battery Replacement
Cosa ti serve
  1. HP ProBook x360 11 G5 EE Battery Replacement, Keyboard Assembly: passo 1, immagine 1 di 3 HP ProBook x360 11 G5 EE Battery Replacement, Keyboard Assembly: passo 1, immagine 2 di 3 HP ProBook x360 11 G5 EE Battery Replacement, Keyboard Assembly: passo 1, immagine 3 di 3
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Battery Replacement: passo 2, immagine 1 di 1
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Battery Replacement: passo 3, immagine 1 di 3 HP ProBook x360 11 G5 EE Battery Replacement: passo 3, immagine 2 di 3 HP ProBook x360 11 G5 EE Battery Replacement: passo 3, immagine 3 di 3
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Battery Replacement: passo 4, immagine 1 di 3 HP ProBook x360 11 G5 EE Battery Replacement: passo 4, immagine 2 di 3 HP ProBook x360 11 G5 EE Battery Replacement: passo 4, immagine 3 di 3
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Battery Replacement: passo 5, immagine 1 di 2 HP ProBook x360 11 G5 EE Battery Replacement: passo 5, immagine 2 di 2
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Battery Replacement, Battery: passo 6, immagine 1 di 2 HP ProBook x360 11 G5 EE Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Battery Replacement: passo 7, immagine 1 di 3 HP ProBook x360 11 G5 EE Battery Replacement: passo 7, immagine 2 di 3 HP ProBook x360 11 G5 EE Battery Replacement: passo 7, immagine 3 di 3
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
Conclusione
eric paz
Membro da: 09/02/21
194 Reputazione
1 Guida realizzata
Gateway, Team 1-4, Pee Fall 2021 Membro di Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
5 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 70
Tutti i Tempi: 2,371
