Salta al contenuto principale
HP ProBook 455 G1 DVD/CD Drive Replacement
Cosa ti serve
  1. HP ProBook 455 G1 DVD/CD Drive  Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 DVD/CD Drive  Replacement: passo 2, immagine 1 di 1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 DVD/CD Drive  Replacement: passo 3, immagine 1 di 2 HP ProBook 455 G1 DVD/CD Drive  Replacement: passo 3, immagine 2 di 2
    • Tilt the battery upward.
    • Remove it from the laptop.
  4. HP ProBook 455 G1 DVD/CD Drive  Replacement, Service Panel: passo 4, immagine 1 di 1
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  5. HP ProBook 455 G1 DVD/CD Drive  Replacement: passo 5, immagine 1 di 2 HP ProBook 455 G1 DVD/CD Drive  Replacement: passo 5, immagine 2 di 2
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
  6. HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: passo 6, immagine 1 di 2 HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: passo 6, immagine 2 di 2
    • Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
    • It will be located in the upper left section of the computer, housed in a small square hole in the computer frame.
    • The Phillips head screwdriver is the screwdriver with a "+" shaped tip. P0 refers to the name/size of this particular Phillips head screwdriver.
  7. HP ProBook 455 G1 DVD/CD Drive  Replacement: passo 7, immagine 1 di 1
    • Using the screwdriver, gently push the silver tab that the screw secured to the left to release the DVD/CD drive from the computer.
  8. HP ProBook 455 G1 DVD/CD Drive  Replacement: passo 8, immagine 1 di 1
    • The DVD/CD drive will be extended from the side of the laptop. Slowly remove it from the computer.
Conclusione
Baylor, Team S5-G1, Williams Spring 2018 Membro di Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 923
