Salta al contenuto principale
HP ProBook 455 G1 Battery Replacement
  1. HP ProBook 455 G1 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 Battery Replacement: passo 2, immagine 1 di 1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 Battery Replacement: passo 3, immagine 1 di 2 HP ProBook 455 G1 Battery Replacement: passo 3, immagine 2 di 2
    • Tilt the battery upward.
    • Remove it from the laptop.
Conclusione
Baylor, Team S5-G1, Williams Spring 2018 Membro di Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 949
