Salta al contenuto principale
HP ProBook 4540s WLAN Module Replacement
Cosa ti serve
  1. HP ProBook 4540s WLAN Module Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s WLAN Module Replacement, Bottom Door: passo 2, immagine 1 di 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s WLAN Module Replacement, WLAN Module: passo 3, immagine 1 di 2 HP ProBook 4540s WLAN Module Replacement, WLAN Module: passo 3, immagine 2 di 2
    • Disconnect the antenna cables from their terminals in the WLAN module.
    • One cable is attached to the Auxiliary ("Aux") terminal, represented with a blue wire. The other cable is connected to the Main terminal which is usually represented with a red wire. These wires can be seen in little windows beside the component.
  4. HP ProBook 4540s WLAN Module Replacement: passo 4, immagine 1 di 2 HP ProBook 4540s WLAN Module Replacement: passo 4, immagine 2 di 2
    • Unscrew two 3.0 mm Phillips PM2.0x3.0 screw securing the module to the computer.
    • The edge of the module that is opposite of the slot is risen away from the computer.
    • Gently lift and remove the module.
Conclusione
Altre 2 persone hanno completato questa guida.
Amber Schindler
Membro da: 10/26/16
1.057 Reputazione
6 Guide realizzate
UW Tacoma, Team 1-5, Rose Fall 2016 Membro di UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,193
