Salta al contenuto principale
HP ProBook 4540s Optical Drive Replacement
Cosa ti serve
  1. HP ProBook 4540s Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
    Chiedi a FixBot
  2. HP ProBook 4540s Optical Drive Replacement, Bottom Door: passo 2, immagine 1 di 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
    Chiedi a FixBot
  3. HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: passo 3, immagine 1 di 2 HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: passo 3, immagine 2 di 2
    • Remove one 6.0 mm Phillips PM2.5x6.0 screw that is securing the optical drive.
    Chiedi a FixBot
  4. HP ProBook 4540s Optical Drive Replacement: passo 4, immagine 1 di 2 HP ProBook 4540s Optical Drive Replacement: passo 4, immagine 2 di 2
    • Press the optical drive tab to release the drive component.
    • Gently pull and remove the component from the computer.
    Chiedi a FixBot
Conclusione
Altre 3 persone hanno completato questa guida.
UW Tacoma, Team 1-5, Rose Fall 2016 Membro di UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 35
Tutti i Tempi: 2,785
